[SOLVED] Ethernet cable help
Mar 2, 2018
32
so i have connected my ethernet cable to the wifi and the pc but nothing happens there is no wifi in the pc and when i go to the change adapter setting ethernet is not there and when i troubleshoot it says inter(r) ethernet connection 1217-V has a driver problem
How can i fix that ?
You won't be able to update the driver without internet. Youll have to look up your motherboard on a different computer and find the ethernet drivers.
Hello,
Search device manager> find network adapter> right click on the ethernet adapter and update
If you have a dell or hp, download their support app and scan drivers also.
https://www.asus.com/us/Motherboards/MAXIMUS_VI_HERO/HelpDesk_Download/
try the lan driver.
