Ethernet cable mounting problem (rented house)
_Artsu_
Commendable
Mar 13, 2016
I need to attach a 20 meter long cable from the router to my room. Since we are in a rented apartment i can't use the cable clips wit the nail on it. So do you have any ideas for what I could do???
Thank you
3M Command line of removable hangers has various wire routing attachments. Easy and non-maring. Where more support is needed, small cable routing attachments are available in the electrical department of the typical big box home store that use a small nail similar to those on a typical large picture hanger. The hole can be spackled over without undue damage to the drywall.
