Hi,
Just registered.
Issue: Trying to connect pc to router via ethernet cable, no lights on router or pc to indicate connection.
Cable ok, tried it in another pc. (plus a spare one)
Device manage says, cannot start it up, code (10).
It has been a while since I used the cable, (couple of years) have been using netgear wifi connection.
The reason for wanting to use cable is that I want to install new hard drive and install windows 7 (64bit), but if I don't have an internet connection I assume I won't be able to. Can't re-install netgear until windows installed. (bit of a chicken and egg situation)
The only changes I have made (due to intermittent start up problems) has been PSU, changed the BIOS chip, (read somewhere that a bad or failing one may stop it doing POST. Some thing worked, not sure what.
I have uninstalled the Realtek controller completely, then using wifi connection downloaded a windows 7 version from Realtek web site and installed it, no luck.
I assume the actual electronic item on the motherboard that the cable plugs into is not something that can be physically replaced?
Grateful for any advice you can give me.
Just registered.
