Ethernet cable with D-Link DSL-2750U Wireless N 300 ADSL2+ 4-Port Wi-Fi Router with Modem
Prasaanth Sekar
I recently bought D-Link DSL-2750U Wireless N 300 ADSL2+ 4-Port Wi-Fi Router with Modem which accepts a DSL connection. But my internet service provider uses an ethernet cable to provide internet. How to use my modem as an access point. Please help.
To use as an access point: Disable DHCP, set up static IP address from your main router' LAN address space, set gateway address to be your main router. Set up WiFi as necessary. But you need to have another router to plug into your ISP' cable
If you can, you better return that combo unit, and get wireless router only.
Prasaanth Sekar
Thanks for your reply. After so many research I just found an answer. I just updated the firmware of my router and it provided me the options to accept ethernet or DSL. So no need to change the router as well. Saves money.
Works fine as well.
chinums2004
cxan u mail me the firmware patch as i also have a similar problem. chinmoy.dash@yahoo.co.in.
Regards
shubham_agrawal4427
Commendable
Apr 30, 2016
Hey... I'm having the same problem , can you forward me that link please?
shubhama4427@gmail.com
Thanks in advance
ovprakash
Commendable
Jun 22, 2016
Dear Prashanth,
Cld you plz explain the trick to use the same modem with ethernet cable. I also struck same issue like you.. I tried lot of ways but not working.
Regards
Prakash
Manish_35
Commendable
Jul 4, 2016
Can you tell me which Firmware to use and from where i can get that firmware?
Similar threads
