ethernet card info
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi All
Am in the process of applying for Predator DSL service in place of my dialup
service. One of the questions that is asked is "Does your computer have a
10/100 Ethernet card?"
I can't answer that question because I really don't know. I checked for
this info on the computer but can't find any info referring to an Ethernet
card. Appreciate any helpful info finding the answer.
Many thanks
Franktee
OS windows XP Home
Dell Inspiron 4000
2001 vintage
Physically examine the back of the PC. You'll have either:
1. A built-in Ethernet port near the Serial & Parallel ports
2. In the PCI slots, you'll see an Ethernet socket with one or
more small LEDs.
If neither exists, then your PC doesn't have Ethernet capability.
Ethernet sockets look similar to RJ Phone sockets, but larger
"Franktee" <Franktee@discussions.microsoft.com> wrote in message
news😀34F48F4-BF59-41E0-9EF6-8F7FB8F9DFCD@microsoft.com...
> Hi All
> dialup
> Many thanks
> Franktee
> OS windows XP Home
> Dell Inspiron 4000
> 2001 vintage
Ethernet adapters are usually referred to as a NIC or network adapter.
As I remember, the Inspiron would be a laptop.
According to the Dell website for the Inspiron 4000, the NIC was optional.
Do you have one listed in device manager?
If not, you can get one that fits into a USB adapter for around $30 at best
Buy, Staples, Circuit City, etc.
I have a couple that are no bigger than a USB Jump Drive.
A Professional Amateur...If anyone knew it all, none of would be here!
> Hi All
> dialup
> Many thanks
> Franktee
> OS windows XP Home
> Dell Inspiron 4000
> 2001 vintage
Good evening NotMe
Thank you for your speedy and most generously detailed response.
I followed your instructions to Device Manager and found the following
hidden folders under Network Adapters.
1. Direct Parallel
2. Infared port
3. Ras async adapter
4. Wan miniport (ip)
5. Wan miniport (ip) packet scheduler miniport
6. Wam miniport (L2TP)
7. Wan miniport (PPPOE)
8. Wan miniport (PPTP)
Would any of the above items possibly be the item I'm searching for?
If not, the $30 investment is easy.
Thanks again for taking the time and trouble responding.
Franktee
> > Hi All
> > dialup
> > Many thanks
> > Franktee
> > OS windows XP Home
> > Dell Inspiron 4000
> > 2001 vintage
Franktee wrote:
> Hi All
Control Panel > System > Hardware > Device Manager.
Do you have a Network Adapter listed under Network Adapters?
It looks like you do NOT have an Ethernet adapter onboard.
My systems show Linksys/3Com/NetGear (or whoever the maker is) 10/100 PCI
Network Controller.
I don't necessarily recommend one brand over another, but look at the
adapters on this page for a start.
http://www.linksys.com/servlet/Satellite?childpagename=US%2FLayout&packedargs=c%3DL_Product_C1%26cid%3D1118334622279&pagename=Linksys%2FCommon%2FVisitorWrapper
I have had good luck with my Linksys stuff.
As a tech, I have also setup many other brands of wired/wireless networks.
I haven't found that 1 is that much better to only consider that brand.
news😀9ECD7D6-F4F3-4E9E-8407-3E23D343CB1B@microsoft.com...
> Good evening NotMe
> 1. Direct Parallel
> 2. Infared port
> Franktee
>> optional.
>> best
>> > Hi All
>> > dialup
>> > a
>> > for
>> > Ethernet
>> > Many thanks
>> > Franktee
>> > OS windows XP Home
>> > Dell Inspiron 4000
>> > 2001 vintage
yes but no mention of ethernet
"Z" wrote:
> Franktee wrote:
> > Hi All
What is listed?
List only the items you see when you expand (with the [+] on the left)
Network Adapters.
Hi Z
Thanks for responding.
The following 8 items are listed under Network Adapters.
!. Direct parallel
2. Infared port
8. Wan miniport (PPTP).
"Z" wrote:
> What is listed?
> Network Adapters.
Franktee wrote:
> Hi Z
> !. Direct parallel
> 2. Infared port
Sorry, I have no idea what those are.
Appreciate your taking the time to help. Thanks
"Z" wrote:
> Franktee wrote:
> > Hi Z
> > !. Direct parallel
> > 2. Infared port
