Hi,
After getting a dirty virus I decided to reinstall windows 8.1.
Ever since, I get the annoying connection limited alert.
My on board WiFi works fine.
I've looked things up all over forums which made me eliminate the following.
A restart gives me the following ipconfig:
After a /release
A /renew
About the DHCP error, it remains the same if I set up a static IPV4.
Please help me.
The ethernetcable does work (tried to get my xbox to xbl and that worked).
Resetting the router/unplugging cables does not matter.
Reinstalling the driver / picking another driver makes no difference.
Reinstalling windows did not work (Yes I'm that desperate).
Disabling IPV6 also makes no difference.
The computer is virus/adware free (clean install).
Firewall does not block any connections.
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V
Physical Address. . . . . . . . . : 10-C3-7B-91-53-3A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e59c:3b22:45e:90b6%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.210(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : donderdag 13 oktober 2016 21:47:47
Lease Expires . . . . . . . . . . : donderdag 13 oktober 2016 22:47:47
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 403751803
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-90-10-DA-54-27-1E-90-A8-14
DNS Servers . . . . . . . . . . . : 195.130.130.2
195.130.131.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 54-27-1E-33-41-90
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 56-27-1E-90-A8-14
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Broadcom 802.11ac Network Adapter
Physical Address. . . . . . . . . : 54-27-1E-90-A8-14
Link-local IPv6 Address . . . . . : fe80::283b:5efe:c819:b4b8%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.236(Preferred)
Lease Obtained. . . . . . . . . . : donderdag 13 oktober 2016 21:57:00
Lease Expires . . . . . . . . . . : donderdag 13 oktober 2016 22:57:00
DHCPv6 IAID . . . . . . . . . . . : 55846686
195.130.131.2
Tunnel adapter isatap.{6508DA43-BB00-4499-9422-5BF05F02B211}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:31:34b1:3f57:ff13(Prefer
red)
Link-local IPv6 Address . . . . . : fe80::31:34b1:3f57:ff13%6(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 251658240
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{38909835-E8DD-47E2-8051-94A16A04B9E4}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
195.130.131.2
195.130.131.2
red)
After a /release
Tunnel adapter Reusable ISATAP Interface {A04F21D8-1FBC-40C3-8D70-E63CAC45DF80}:
Media State . . . . . . . . . . . : Media unoperational
A /renew
C:\Windows\system32>ipconfig /renew
Windows IP Configuration
An error occurred while renewing interface Ethernet : unable to contact your DHC
P server. Request has timed out.
No operation can be performed on Bluetooth Network Connection while it has its m
edia disconnected.
No operation can be performed on Local Area Connection* 2 while it has its media
disconnected.
Autoconfiguration IPv4 Address. . : 169.254.144.182
Subnet Mask . . . . . . . . . . . : 255.255.0.0
edia disconnected.
disconnected.
Please help me.
