Question Ethernet connection not working following CPU upgrade.
BPR96
84
Hi all,
So today I swapped out my Ryzen 5 3600 to a Ryzen 7 5700x. I updated the BIOS before hand.
Since I have installed it, my ethernet connection has been on and off at best. At times it will show the "not connected" symbol, then other times it will show that I am connected but nothing loads, and then for a short while I will be connected to the internet just for it to cut out again.
I have reset Windows, hasn't fixed it. I have installed the ethernet driver and it's still not working. I have no idea what has caused it because it was working perfectly before the new CPU install.
Any idea on what could be causing this?
Thanks all.
I would be suspect of the bios.
The ethernet chip runs off the chipset not the the cpu directly. The chipset is the same as it was before. I don't think the cpu chip has any directly support for network stuff...at least I think it doesn't I have not looked into the details of amd lately.
just updated BIOS to a later version and still no luck.
Last bet is to just completely wipe windows and reinstall it fresh, see if that works.
Failing that, I guess just install my old CPU and install an older bios and call it a day.
In Device Manager >Network adapters find and select your network card. A window should appear with multiple tabs providing more information about the network adapter and its' properties. Check all tabs - be sure to look in Events.
Also look in Reliability History/Monitor and Event Viewer.
Either one or both tools may be capturing some network/network card related error codes, warnings, or even informational events when the Ethernet connection goes "on and off".
Hi,
Checked all the network adapters and every one is saying it is configured.
Still isn't working
