Question Ethernet connection unstable..
Feb 16, 2019
Last week I built my new PC and I got it running fine. However when I first built it I had a problem where the connection kept dropping. After running the PC for a while it stabilises then in about 3-4 hours starts dropping again. It gets really annoying when I'm trying to game on it or download something.
I use a device that gets the Ethernet connection from the Router downstairs, sends the signal through the mains and is recieved by the other device. I considered this may be a source of the problem but it doesn't cause any problems on my PS4.
I thought maybe its the wiring on the motherboard isn't connected properly but the Ethernet is built in to my motherboard so I doubt it.
Here is my build if it helps in any way: https://pcpartpicker.com/list/LprkZR
Thanks in Advance,
Elmon
Jan 3, 2019
36
Did you Install the Network Drivers for your motherboard?
Here's the link , Select LAN Drivers, Some times windows 10 install outdated drivers, try downloading it manually and install, maybe that will fix your problem.
Feb 16, 2019
Thanks, I just installed them. As I said in my post it takes a couple hours to mess up so I will update you. Thanks so much for your help!
