Ethernet Controller Drivers not installed
jgamingb
I recently put upgraded my PC by installing a CPU Cooler. After putting the cooler in the PC I plugged all the plugs back in and I wasn't able to get internet connection.
I was getting No connection. Internet was working fine. I tried different Ethernet cables, nothing changed.
I saw some suggestions on uninstalling Ethernet drivers and restarting your computer will reinstall them. Well I did that and now the Drivers wont install.
In the device manager this comes up
Ethernet Controller.
The drivers for this device are not installed. (Code 28)
There are no compatible drivers for this device.
I am at a lost here I tried to look online for Ethernet Drivers but there are different kinds of drivers and I have no idea which ones I should install. So if someone can help me I would really appreciate it.
I got Hardware Id's if that helps:
PCI\VEN_1969&DEV_E091&SUBSYS_78211462&REV_13
PCI\VEN_1969&DEV_E091&CC_020000
My Motherboard is an MSI Z87-G45 GAMING.
What Ethernet adapter are you using?
Built in motherboard or some PCIe card?
If the latter:
Open the PC and verify that the Ethernet adapter is fully and securely in place.
Also ensure that only one Ethernet adapter (motherboard or PCIe) is enabled.
Run and post the results of "ipconfig /all" (without quotes) via the command prompt.
