S sasho123 Prominent Jun 1, 2017 1 0 510 Jun 1, 2017 #1 My router broke and i have to use direct connection on my computer.Can someone tell me how to change the connection from wi-fi to direct?
Solution James Mason Jun 1, 2017 All you should have to do is plug it in, but that's only with a working router. You need a router, you can't just use a modem.
James Mason Titan Jan 2, 2014 13,551 8 74,965 Jun 1, 2017 Solution #2 All you should have to do is plug it in, but that's only with a working router. You need a router, you can't just use a modem. Upvote 0 Downvote Solution
