Z Zahid Malik1 Commendable May 19, 2016 34 0 1,540 May 20, 2016 #1 how long does a CAT6 ethernet cable works?
Solution kanewolf May 20, 2016 Spec says 100 meters. You can probably go 110 or 120m if you do good terminations.
Robert Cook Expert Ambassador Dec 15, 2014 6,113 0 21,960 May 20, 2016 #2 It is rated for 100 meters without data loss assuming ten meters of connection cables ( so 90 meters). you might get more, you might not, but that is a pretty good length. Upvote 0 Downvote
Z Zahid Malik1 Commendable May 19, 2016 34 0 1,540 May 20, 2016 #3 can u please suggest me a good high performance ram for my motherboard Foxconn H61MD Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,637 22,011 184,590 May 20, 2016 #4 Zahid Malik1 : how long does a CAT6 ethernet cable works? 100 meters. Less if you have a crappy cable. Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,645 3,806 156,790 May 20, 2016 Solution #5 Spec says 100 meters. You can probably go 110 or 120m if you do good terminations. Upvote 0 Downvote Solution
