Ralston18 :
Did you disable the wireless network adapter? You should do that if you are trying to go back to wired connectivity.
Reseat the Asus network adapter. Then uninstall and reinstall the newest (verify to be sure) drivers for the card. Reconfigure the adapter to the campus wired network.
Run and post the results of "ipconfig /all" from the command prompt.
The idea being to understand what your current wired network configuration is. Could simply be an configuration error or typo.
Ok I uninstalled both and reinstalled the most updated drivers I could
http://i.imgur.com/oa4iO3j.png
Yeah I have diabled the wireless connection and it doesnt work. The asus is for my wireless connection so I am not sure reseting it will do anything BUT I WILL TRY IT since idk much about computers. But how do I do that? Lol I used the network reset option on windows 10 if you look it up in the start menu that is what I used.
Not sure if this is relevant information.
Client Log
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.QuickConnectDlg - Starting configuration.
2016-12-12 23:26:27,389 [main] DEBUG changelog - Starting configuration for secure network connections.
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Util - Attempting operating system detection.
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Util - running Windows Enterprise Version
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Util - Detected operating system Vista/Windows7
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.WlanApi - Initializing wlan api.
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Config - Initing configuration.
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Config - QuickConnect Mode isstandalone
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Config - Found network definition : Wired 802.1x-20140903
2016-12-12 23:26:27,389 [main] DEBUG Quick1X.Config - Operating Systems List : 1,2
2016-12-12 23:26:29,326 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method : updateWorkingDirectory
2016-12-12 23:26:30,748 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method : updateQcMode
2016-12-12 23:26:30,764 [main] DEBUG Quick1X.QuickConnectDlg - Processing network selction
2016-12-12 23:26:30,764 [main] DEBUG Quick1X.QuickConnectDlg - Single network defined in config file :['Wired 802.1x-20140903']
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.QuickConnectDlg - Processing credential requirements
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Initing common profile.
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Checking admin credentials.
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Admin credentials not found.
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Initing wireless profile
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Wireless section does not exist.
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.Config - Initing wired profile
2016-12-12 23:26:30,779 [main] DEBUG Quick1X.QuickConnectDlg - Credentials are required.
2016-12-12 23:26:40,400 [main] DEBUG Quick1X.QuickConnectDlg - Processing Requirements
2016-12-12 23:26:40,400 [null] DEBUG Quick1X.QuickConnectDlg - Processsing requirements task
2016-12-12 23:26:40,400 [null] DEBUG Quick1X.QuickConnectDlg - Initing device info
2016-12-12 23:26:40,400 [null] DEBUG Quick1X.DeviceInfo - Starting interface detection
2016-12-12 23:26:40,400 [null] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:27:34,121 [null] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface Type :71
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface state :2
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Discarding interface : Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface Type :6
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface state :1
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:102C1289-552F-4DF8-8F09-CD4AD8BB7277
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Description: Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Name: Ethernet
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - State: CONNECTED
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - MAC Address: D8:CB:8A:71:65
😀E
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wired
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Checking interface :ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:4C7543CA-AAA3-49A8-B0CF-9D9A83E92537
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Description: ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Name: Wi-Fi
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - MAC Address: 9C:5C:8E:B4:3D:76
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wireless
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Software Loopback Interface 1
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.DeviceInfo - Interface Type :24
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.QuickConnectDlg - Initing configurator
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Detecting service status for dot3svc
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service dot3svc is auto start
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service dot3svc is running
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Detecting service status for Wlansvc
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service Wlansvc is auto start
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service Wlansvc is running
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Detecting service status for wscsvc
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service wscsvc is auto start
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Service wscsvc is NOT running
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Detecting service status for napagent
2016-12-12 23:27:34,136 [null] ERROR Quick1X.Configurator - Could not open service handle for napagent
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Checking NAP QEC registry key
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Registry - Could not open registry key for reading
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - NAP 802.1X QEC is disabled
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.QuickConnectDlg - Wireless connection, GUID: 4C7543CA-AAA3-49A8-B0CF-9D9A83E92537 Name: Wi-Fi
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.QuickConnectDlg - Wired connection, GUID: 102C1289-552F-4DF8-8F09-CD4AD8BB7277 Name: Ethernet
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.QuickConnectDlg - Checking if admin credentials are required
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - No applications have to be installed
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.Configurator - Admin access neeeded to configure wired
2016-12-12 23:27:34,136 [null] DEBUG Quick1X.QuickConnectDlg - Admin credentials required
2016-12-12 23:27:34,480 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method :adminAccessRequired
2016-12-12 23:27:34,496 [main] DEBUG Quick1X.QuickConnectDlg - Processing configure
2016-12-12 23:27:34,496 [null] DEBUG Quick1X.QuickConnectDlg - Processsing configure task
2016-12-12 23:27:34,496 [null] DEBUG Quick1X.QuickConnectDlg - Configuring windows supplicant
2016-12-12 23:27:34,496 [null] DEBUG Quick1X.QuickConnectDlg - Initing device info
2016-12-12 23:27:34,496 [null] DEBUG Quick1X.DeviceInfo - Starting interface detection
2016-12-12 23:27:34,496 [null] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface Type :71
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface state :2
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Discarding interface : Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface Type :6
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface state :1
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:102C1289-552F-4DF8-8F09-CD4AD8BB7277
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Description: Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Name: Ethernet
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - State: CONNECTED
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - MAC Address: D8:CB:8A:71:65
😀E
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wired
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Checking interface :ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:4C7543CA-AAA3-49A8-B0CF-9D9A83E92537
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Description: ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Name: Wi-Fi
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - MAC Address: 9C:5C:8E:B4:3D:76
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wireless
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Software Loopback Interface 1
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.DeviceInfo - Interface Type :24
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.QuickConnectDlg - Wireless connection, GUID: 4C7543CA-AAA3-49A8-B0CF-9D9A83E92537 Name: Wi-Fi
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.QuickConnectDlg - Wired connection, GUID: 102C1289-552F-4DF8-8F09-CD4AD8BB7277 Name: Ethernet
2016-12-12 23:27:34,590 [null] DEBUG Quick1X.Configurator - Iinitializing wired device
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.CProfileBuilder - Certificates for wired
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.CProfileBuilder - Certificate ID: cert_352
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.CProfileBuilder - Thumbprint : B1BC968BD4F49D622AA89A81F2150152A41D829C
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Configurator - Installing certificates to User
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Configurator - Attempting to install cert cert_352.der
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.CertificateStore - Added certificated to trusted store of User
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Configurator - No TLS certificate needs to be installed
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Configurator - No applications have to be installed
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Configurator - Admin access neeeded to configure wired
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.QuickConnectDlg - Configuration requires Admin credentials
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Util - Running admin configurator helper
2016-12-12 23:27:34,605 [null] DEBUG Quick1X.Util - Launching admin helper, requesting elevation.
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.Util - Admin helper script exited with 0
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Verifying admin configuration tasks
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Verified system services configuration
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Verified NAP configuration
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Config admin helper configured Wired device
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Verified wireless IP settings configuration
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Verified wired IP settings configuration
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.Configurator - Initializing wireless device
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.NetworkInterfaceWlan - Autoconfig is enabled on wireless interface
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.Configurator - Got profiles to delete
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.Configurator - Configuring wireless profile
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.Configurator - Wireless profile is empty
2016-12-12 23:31:00,714 [null] DEBUG Quick1X.QuickConnectDlg - Connect To Network Available
2016-12-12 23:31:00,980 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method :configureCompleted
2016-12-12 23:31:04,465 [main] DEBUG Quick1X.QuickConnectDlg - Processing connect
2016-12-12 23:31:04,465 [null] DEBUG Quick1X.Configurator - Attempting to connect
2016-12-12 23:31:04,465 [null] DEBUG Quick1X.Configurator - Checking connection to wired network
2016-12-12 23:31:04,465 [null] DEBUG Quick1X.DeviceInfo - Starting ip address detection
2016-12-12 23:32:29,047 [null] ERROR Quick1X.Configurator - Connecting to wired network failed.
2016-12-12 23:32:29,047 [null] ERROR Quick1X.QuickConnectDlg - Wired device could not connect
2016-12-12 23:32:29,047 [null] DEBUG Quick1X.Util - Running config task as logged in user
Script Log
12/11/2016 1:48:04 PM Adapter type detect starting
12/11/2016 1:48:04 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 1:48:04 PM Teredo Tunneling Pseudo-Interface Type: 0
12/11/2016 1:48:04 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 1:48:04 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 1:48:04 PM Microsoft ISATAP Adapter #2 Type: 0
12/11/2016 1:48:05 PM Adapter type detect starting
12/11/2016 1:48:05 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 1:48:05 PM Teredo Tunneling Pseudo-Interface Type: 0
12/11/2016 1:48:05 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 1:48:05 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 1:48:05 PM Microsoft ISATAP Adapter #2 Type: 0
12/11/2016 1:48:06 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 1:48:06 PM DHCP Release return code : 83
12/11/2016 1:48:16 PM DHCP renew starting for {AF4FE3FE-4BBF-417F-844D-8A6923BF0A88}
12/11/2016 1:48:16 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 1:49:26 PM DHCP renew return code :0
12/11/2016 8:22:54 PM Adapter type detect starting
12/11/2016 8:22:54 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 8:22:54 PM Microsoft ISATAP Adapter #3 Type: 0
12/11/2016 8:22:54 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 8:22:54 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 8:22:56 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:22:59 PM DHCP Release return code : 0
12/11/2016 8:23:09 PM DHCP renew starting for {AF4FE3FE-4BBF-417F-844D-8A6923BF0A88}
12/11/2016 8:23:09 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:23:15 PM DHCP renew return code :0
12/11/2016 8:25:11 PM Adapter type detect starting
12/11/2016 8:25:11 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 8:25:11 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 8:25:11 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 8:25:11 PM Microsoft ISATAP Adapter #3 Type: 0
12/11/2016 8:25:12 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:25:13 PM DHCP Release return code : 0
12/11/2016 8:25:23 PM DHCP renew starting for {AF4FE3FE-4BBF-417F-844D-8A6923BF0A88}
12/11/2016 8:25:23 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:25:29 PM DHCP renew return code :0
12/11/2016 8:27:58 PM Adapter type detect starting
12/11/2016 8:27:58 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 8:27:58 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 8:27:58 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 8:27:58 PM Microsoft ISATAP Adapter #3 Type: 0
12/11/2016 8:27:59 PM Adapter type detect starting
12/11/2016 8:27:59 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/11/2016 8:27:59 PM Microsoft Wi-Fi Direct Virtual Adapter Type: 9
12/11/2016 8:27:59 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/11/2016 8:27:59 PM Microsoft ISATAP Adapter #3 Type: 0
12/11/2016 8:27:59 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:28:02 PM DHCP Release return code : 0
12/11/2016 8:28:12 PM DHCP renew starting for {AF4FE3FE-4BBF-417F-844D-8A6923BF0A88}
12/11/2016 8:28:12 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/11/2016 8:28:18 PM DHCP renew return code :0
12/12/2016 11:26:42 PM Adapter type detect starting
12/12/2016 11:27:34 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/12/2016 11:27:34 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/12/2016 11:27:34 PM Microsoft Wi-Fi Direct Virtual Adapter #2 Type: 9
12/12/2016 11:27:34 PM Microsoft ISATAP Adapter Type: 0
12/12/2016 11:27:34 PM Microsoft ISATAP Adapter #2 Type: 0
12/12/2016 11:27:34 PM Adapter type detect starting
12/12/2016 11:27:35 PM Adapter type detect starting
12/12/2016 11:27:35 PM Killer E2200 Gigabit Ethernet Controller Type: 0
12/12/2016 11:27:35 PM ASUS PCE-N15 11n Wireless LAN PCI-E Card Type: 9
12/12/2016 11:27:35 PM Microsoft Wi-Fi Direct Virtual Adapter #2 Type: 9
12/12/2016 11:27:35 PM Microsoft ISATAP Adapter Type: 0
12/12/2016 11:27:35 PM Microsoft ISATAP Adapter #2 Type: 0
12/12/2016 11:28:41 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/12/2016 11:28:41 PM DHCP Release return code : 0
12/12/2016 11:28:51 PM DHCP renew starting for {102C1289-552F-4DF8-8F09-CD4AD8BB7277}
12/12/2016 11:28:51 PM Adapter :Killer E2200 Gigabit Ethernet Controller
12/12/2016 11:31:00 PM DHCP renew return code :82
Helper Log
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.WlanApi - Initializing wlan api.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.QuickConnectHelper - Initing config
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.QuickConnectHelper - Selected network Wired 802.1x-20140903
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Util - Attempting operating system detection.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Util - running Windows Enterprise Version
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Util - Detected operating system Vista/Windows7
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Initing configuration.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - QuickConnect Mode isstandalone
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Found network definition : Wired 802.1x-20140903
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Operating Systems List : 1,2
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.QuickConnectHelper - Inited config
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.QuickConnectHelper - Initing profiles
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Initing common profile.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Checking admin credentials.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Admin credentials not found.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Initing wireless profile
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Wireless section does not exist.
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Config - Initing wired profile
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.QuickConnectHelper - Initing device info
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.DeviceInfo - Starting interface detection
2016-12-12 23:27:35,277 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Checking interface :Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Interface Type :71
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Interface state :2
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Discarding interface : Microsoft Wi-Fi Direct Virtual Adapter #2
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Checking interface :Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Interface Type :6
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Interface state :1
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Adapter GUID:102C1289-552F-4DF8-8F09-CD4AD8BB7277
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Description: Killer E2200 Gigabit Ethernet Controller
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - Name: Ethernet
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - State: CONNECTED
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
2016-12-12 23:27:35,558 [main] DEBUG Quick1X.DeviceInfo - MAC Address: D8:CB:8A:71:65
😀E
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Interface type : Wired
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Checking interface :ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Interface Type :71
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Interface state :1
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Adapter GUID:4C7543CA-AAA3-49A8-B0CF-9D9A83E92537
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Description: ASUS PCE-N15 11n Wireless LAN PCI-E Card
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Name: Wi-Fi
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - State: CONNECTED
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - MAC Address: 9C:5C:8E:B4:3D:76
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Interface type : Wireless
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Checking interface :Software Loopback Interface 1
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.DeviceInfo - Interface Type :24
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Initing configurator
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Detecting service status for dot3svc
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service dot3svc is auto start
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service dot3svc is running
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Detecting service status for Wlansvc
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service Wlansvc is auto start
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service Wlansvc is running
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Detecting service status for wscsvc
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service wscsvc is auto start
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Service wscsvc is NOT running
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Detecting service status for napagent
2016-12-12 23:27:35,574 [main] ERROR Quick1X.Configurator - Could not open service handle for napagent
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Checking NAP QEC registry key
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Registry - Could not open registry key for reading
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - NAP 802.1X QEC is disabled
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Got credentials for username: tug80282
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - TLS certificate not required
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Starting configuration
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Wireless connection, GUID: 4C7543CA-AAA3-49A8-B0CF-9D9A83E92537 Name: Wi-Fi
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Wired connection, GUID: 102C1289-552F-4DF8-8F09-CD4AD8BB7277 Name: Ethernet
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.QuickConnectHelper - Doing admin requirement computation
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - No applications have to be installed
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Admin access neeeded to configure wired
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Configuring system services
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Wired services are required
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Wired service is already running and auto start
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Configured system services successfully
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Iinitializing wired device
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Checking applications to install
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Machine certificate installation not required
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Configuring wired profile
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - Applying following profile
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Configurator - <?xml version="1.0" encoding="US-ASCII"?>
<LANProfile xmlns="http://www.microsoft.com/networking/LAN/profile/v1">
<MSM>
<security>
<OneXEnforced>false</OneXEnforced>
<OneXEnabled>true</OneXEnabled>
<OneX xmlns="http://www.microsoft.com/networking/OneX/v1">
<authMode>user</authMode>
<EAPConfig>
<EapHostConfig xmlns="http://www.microsoft.com/provisioning/EapHostConfig"
xmlns:eapCommon="http://www.microsoft.com/provisioning/EapCommon"
xmlns:baseEap="http://www.microsoft.com/provisioning/BaseEapMethodConfig"
<EapMethod>
<eapCommon:Type>25</eapCommon:Type>
<eapCommon:AuthorId>0</eapCommon:AuthorId>
</EapMethod>
<Config xmlns:baseEap="http://www.microsoft.com/provisioning/BaseEapConnectionPropertiesV1"
xmlns:msPeap="http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV1"
<baseEap:Eap>
<baseEap:Type>25</baseEap:Type>
<msPeap:EapType>
<msPeap:ServerValidation>
<msPeap
😀isableUserPromptForServerValidation>false</msPeap
<msPeap:ServerNames>nac.temple.edu</msPeap:ServerNames>
<msPeap:TrustedRootCA>B1BC968BD4F49D622AA89A81F2150152A41D829C</msPeap:TrustedRootCA>
</msPeap:ServerValidation>
<msPeap:FastReconnect>true</msPeap:FastReconnect>
<msPeap:InnerEapOptional>0</msPeap:InnerEapOptional>
<baseEap:Eap
xmlns:msChapV2="http://www.microsoft.com/provisioning/MsChapV2ConnectionPropertiesV1"
<baseEap:Type>26</baseEap:Type>
<msChapV2:EapType>
<msChapV2:UseWinLogonCredentials>false</msChapV2:UseWinLogonCredentials>
</msChapV2:EapType>
</baseEap:Eap>
<msPeap:EnableQuarantineChecks>false</msPeap:EnableQuarantineChecks>
<msPeap:RequireCryptoBinding>false</msPeap:RequireCryptoBinding>
<msPeap
😛eapExtensions><PeapExtensionsV2 xmlns="http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV2">
<AllowPromptingWhenServerCANotFound xmlns="http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV3">
true
</AllowPromptingWhenServerCANotFound>
</PeapExtensionsV2>
</msPeap
😛eapExtensions>
</msPeap:EapType>
</baseEap:Eap>
</Config>
</EapHostConfig>
</EAPConfig>
</OneX>
</security>
</MSM>
</LANProfile>
2016-12-12 23:27:35,574 [main] DEBUG changelog - Wired interface selected for configuration: Ethernet
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.NetworkInterfaceLan - Creating credentials for LAN profile
2016-12-12 23:27:35,574 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:27:46,461 [main] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:27:46,461 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.NetworkInterfaceLan - Set credentials for LAN profile
2016-12-12 23:28:41,711 [main] DEBUG changelog - Enabled 802.1X authentication on Ethernet
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Configurator - Successfully configured wired
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Configurator - Checking if ip config is required to wired network
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Configurator - IP configuration is not needed for wired
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Configurator - Connecting to wired network
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.NetworkInterface - Releasing DHCP lease on Ethernet
2016-12-12 23:28:41,711 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:28:41,836 [main] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:28:41,836 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:28:41,898 [main] DEBUG Quick1X.Util - Exit code from execed process 0
2016-12-12 23:28:41,898 [main] DEBUG Quick1X.NetworkInterfaceLan - Waiting for interface to connect
2016-12-12 23:28:51,918 [main] DEBUG Quick1X.NetworkInterface - Trying to renew DHCP lease on Ethernet
2016-12-12 23:28:51,918 [main] DEBUG Quick1X.Util - Running config task as logged in user
2016-12-12 23:31:00,699 [main] DEBUG Quick1X.Util - Exit code from execed process 0
