J James_525 Prominent Mar 8, 2017 12 0 510 Mar 8, 2017 #1 I Just built a new PC and my wifi is working fine but when i plug my ethernet in it doesn't connect me to the internet. The ids for the ethernet controller is Ven_1969&DEV_E0A1 Specs. Mobo: MSI Z170A M7 CPU: I7 6700k GPU: MSI 1070
Solution getochkn Mar 8, 2017 https://ca.msi.com/Motherboard/support/Z170A-GAMING-M7.html#down-driver ONBOARD LAN DRIVERS FROM THERE. PICK YOUR OS
getochkn Polypheme Jul 2, 2006 12,406 54 65,040 Mar 8, 2017 #2 did you install drivers? Upvote 0 Downvote
J James_525 Prominent Mar 8, 2017 12 0 510 Mar 8, 2017 #3 I don't know what drivers to install Upvote 0 Downvote
getochkn Polypheme Jul 2, 2006 12,406 54 65,040 Mar 8, 2017 Solution #4 https://ca.msi.com/Motherboard/support/Z170A-GAMING-M7.html#down-driver ONBOARD LAN DRIVERS FROM THERE. PICK YOUR OS Upvote 0 Downvote Solution
J James_525 Prominent Mar 8, 2017 12 0 510 Mar 8, 2017 #5 Thanks for the help it worked Upvote 0 Downvote
