I have a really bizarre problem here, I ran a cat5e cable from my PC to the router which is about 50m away, however it wont connect unless I set the speed at 10 Mbps, I thought there is a problem with the cable for sure, I re-did both endings with the same result, so I might as will change the entire cable, so I got a cat6 cable this time, same exact result 10 Mbps only.
I had an old switch laying around which has (10/100mbps ports) so I tried running it and put it next to the router, with the same exact cable (cat5e) and I got 100 Mbps speed.
Is there any reason on why this is happening ?
My router is TP-Link Archer C50, which supports 4x100mbps LAN, and I can see the full 100mbps on the router page when I connect the old switch to it directly.
