[SOLVED] Ethernet speed slower than advertised
LateFlex
6
Our carrier advertised us 500mb/s but on my PC I'm only getting 5-9Mb/s. I'm using a cat5e cable (20m) directly plugged into a gigabyte port on my PC, which is connected to a gigabyte switch which is then connected to our router . I'm not sure as to how to fix this and would love any tips give.
(sorry for any mistakes, since this is my first post)
Another question: make and model switch?
Are you able to run a test bypassing the switch: i.e., by using a longer ethernet cable or by temporarily moving the PC?
Just a matter of elimination.....
the switch is the TL-SG105E 5 port switch. although bypassing the switch sped it up to about 50mb/s.
thank you very much for the solution. this isn't the 100mb/s that my motherboard can take but im still happy.
Latest posts
