Ethernet to wireless
Kedeli
104
I'm looking for a product that allows you insert a device into a wall socket beside your router, put an Ethernet cable into that which then runs the internet connection through your walls. Another connector is inserted into a plug socket beside your computer, allowing you to have wired internet if your router is not in the same room as your computer. Does anyone know the name of these connectors?
