I recently purchased a game called Euro Truck Simulator 2 and I've noticed that it has a lot of performance issues. A few days ago the game (on Ultra) was playing at a horrible 19 FPS everywhere in the game, but only using 10-15% CPU and 30-50% GPU!!! I recently saw a HUGE improvement in performance by disabling an option called "Refresh Rate". On highways and away from cities it now gets 45-60 FPS and my GPU usage hovers around 80-99%, where it should be.
But there is still an issue I need resolved. When I drive into a city the FPS goes back down to 19, and my GPU usage goes back down to 30-50%!!! WTF
?! And, here is another thing I noticed; when I'm in the city and change the camera mode from inside the truck to outside, the FPS goes back up to 45-60 and my GPU goes back up to 70-90% usage! That means that it is not my computer, it is inefficient code or a leak somewhere. When I do certain things it is as if something in the code or options is limiting my GPU. Do you guys know of anything I can try to stop this from happening? Maybe you guys know of something else that is buggy that I can disable in the options that is causing a leak? Something else? Also, every time my GPU usage dips to 30-50% my CPU is still at 15-30%, so it's not like my CPU isn't supplying enough info or anything like that.
Here is my rig:
GPU: EVGA NVIDIA GeForce GTX 670 FTW 2GB
CPU: AMD Phenom II X6 1035T 2.6GHz
RAM: 6GB DDR3
OS: Windows 7 64-bit
Resolution: 1920 x 1080
PS: My graphics drivers are up to date (310.90) and I have the latest version of the game (v2.1.2.5.1)
PS😛S: I also tried lowering the graphics to medium and high, but no improvement.
Thanks
?! And, here is another thing I noticed; when I'm in the city and change the camera mode from inside the truck to outside, the FPS goes back up to 45-60 and my GPU goes back up to 70-90% usage! That means that it is not my computer, it is inefficient code or a leak somewhere. When I do certain things it is as if something in the code or options is limiting my GPU. Do you guys know of anything I can try to stop this from happening? Maybe you guys know of something else that is buggy that I can disable in the options that is causing a leak? Something else? Also, every time my GPU usage dips to 30-50% my CPU is still at 15-30%, so it's not like my CPU isn't supplying enough info or anything like that.Here is my rig:
RAM: 6GB DDR3
Thanks
