[SOLVED] euro truck simulator 2 texture issue
Mar 6, 2020
4
ive downloaded and installed codex versions of ets2 1.36.2.2, when i run it, my texture/graphics are completely messed up, i only see rgb colors and lines, i dont know if thats because of direct x 11 or my gpu, im using a dell e6410, has nvidia nvs3100m i dont know what to do now, i tried to reinstall same version from multiple sites, still same issue, that issue wasn't present in 1.35 help me please View: https://imgur.com/a/PHC3xi1
thats how it looks
Which version of Nvidia's drivers are you working with? I think the reason you're seeing those issue is the fact you're on a dated workstation GPU and the game does not support it.
Use DDU to uninstall your GPU drivers and reinstall with the latest version found off of Nvidia's support site.
i tried to update driver, also tried to reinstall latest version available on nvidia site, but it doesn't seem to have fixed anything. also when i try to close game, it fixes textures for 1sec while game being closed but then again breaks
