PLZ read/answer thoroughly. Sorry for the many posts regarding my new system. Hopefully this will be the last as it seems things are solidifying.
This all started as a $150 upgrade... now its a new system, but I'm getting by for $500 by selling off old parts from my old comp, salvaging stuff some of the stuff from the system I sold, and I've found some great deals.
My rationale: see my sig for current main-system specs, which is a northwood socket 478 cpu w/AGP slot and no 64bit. This system is has no part in the upgrade. However my though is, it has minimal future expandibility it seems. I wanted to update my secondary computer already, but it keeps turning into a bigger/better update. Now I am upgrading it (on an AMD platform), with the thought that in the Fall of 2006 I can keep the new case/mobo/ram I'm about to buy, and just swap in a new CPU & GPU, and put some big SATA2 HD's and nice optical drives in, etc.
So basically right now, this will be a secondary computer, but I am setting it up to, in 1.5 years, to turn into my MAIN rig... this meaning "base" items (like mobo/ram/case/psu) must be high quality to last me; but the CPU/GPU will be swapped out later. Not sure on how the RAM will hold up and play a part in the CPU upgrade, I need some advice on that (questions later)
Anyway here is what I have so far:
1GB (2x512) Kingston HyperX DDR Pc3200 RAM
XFX GeForce 6600GT PCI-E
160GB EIDE Seagate 7200rpm HD
Pioneer 4x DVD-RW burner
I have all peripherals already...
HERE IS WHAT I AM ON THE VERGE OF BUYING:
Antec Performance One P160 ATX Mid-Tower
http://www.pcabusers.com/reviews/antec/p160/p1.htm
Antec TruePower 550W PSU - $105
http://www.compuplus.com/insidepage.php3?id=806&refer=pricewatch.com#moreinfo
(is this the new ATX 2.0 standard??)
Athlon64 s939 3000+ Retail CPU, Winchester core
1.) What do you think of the Antec case? It will set me back $110 + $100 for the PSU. I want to get a good case/PSU, but still budget is an option. Am I spending too much here? Any better alternatives? I'm looking for a non-side window, sleek high quality silver case.
2.) PSU - Is that Antec a v2.0 ATX PSU? Would you recommend that one, or is there a better one to go with? What do you think of Antec VS Fortron 500W ATX 2.0? Any others? I want ATX2.0 and high quality. I think that Antec is 2.0 but can someone confirm?
3.) Winchester core, or what is this I hear of the new venice core or something? Whats the difference, does it matter, which should I get and why?
4.) 3000+, or 3200+ for $40 more? Is the $40 worth it? Right now this well be a secondary rig and I am planning to swap in a dual core, high end CPU in 1.5 years. But still, if I gain a lot of performance for $40 I'll do it. Thoughts?
5.) Motherboard... help help help. I just can't decide. Here is what is important to me:
-- Socket 939 + PCI-E, of course
-- 4 SATA 2 connections (SATA2!!)
-- Firewire support
-- Standard stuff like integrated LAN and sound.
-- I can go with or without SLI, unless SLI is about same price on a great board.
-- 2 EIDE (ATA/133) connections
-- I have no plans on overclocking. But just in case I do someday the board should be decent for it... but thats definetly a secondary concern.
-- I want top quality components. I know ASUS/ABIT make top quality, now I am hearing of DFI & epox. Too many choices, I know ppl have helped, help me make up my mind though!
6.) Is the RAM I got "superb" - "great" - "good" - "standard" - "sub-standard", and how will this effect my future upgrade plans as I mentioned (1.5yr upgrade, dual core, etc.) --- here is the link with timings and everything:
http://shop2.outpost.com/product/3746176?site=sr:SEARCH:MAIN_RSLT_PG
Everywhere else on the next this same model number seems to be going for $180. Check pricewatch you will see. Anyway how is it?
*** How does my "plan" sound for the longevity, 1.5 year upgrade on this?? ***
-- Will the DDR ram still work with the new dual cores and higher speeds, or will I need DDR2? Will Pc3200 still be ok? Is not having DDR2 going to kill my plans? How will my Kingston RAM hold u p?
-- Will the motherboard hold up to s939 chips 1.5 years down the road?
-- Any reason why my plans won't work? Anything I'm missing? Future Dual Cores/Faster clockspeeds processors will be built on s939 and work with the mobo I buy right?
-- Again, this future life of the system is important in my mobo choice.
Sorry... I know this a long read, a ton of questions... but if I could get some thorough answers and help on this it would be greatly appreciated. Please help me out
And please don't skip any of the questions (from case/PSU stuff, to processor, RAM, mobo, 1.5yr upgrade plan) - all that stuff.
Thank you SO much.
Dan
P4c 3.2Ghz @ 800MHz Northwood / ABIT AI7 / 1GB Corsair XMS-Pro CL2 Pc3200 / 160GB Seagate SATA 7200rpm 8mb cache / BFG-Tech Nvidia GeForce 6800GT 256mb / Antec Sonata case w/Antec TruePower 380W PSU
-- Firewire support
Thank you SO much.
Dan
