Event ID 41 - Kernel Power
Otacons
46
Hello everyone.
I would need your help to sort this error out, I've had 3 bluscreens over the past 10 days and I would need some clue about what it could be.
My configuration is:
AMD FX 8350 4Ghz - NO OC
Cooler Master TX3 EVO
Asus GTX 760
8GB RAM (4x2) Kingston 1333
Asrock 970 pro3 r2.0
Corsair Gaming Series GS800w 80+ Bronze
Win 7 PRO 64 BIT Retail License
I tried a virus scan with avast and not threats found.
Also tried with sfc/scannow but nothing was found either.
Tried to scan the disk but that has no problems at all too.
I ran a scan with advanced system care to repair the registry, seemed like there was a good number of errors so I repaired all of them. I haven't encountered any more blu screens for now.
But anyway here are the screens I got myself into:
_______________________
SCREEN 1:
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2014-01-16T19:12:01.126815100Z
EventRecordID 16519
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Utente-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 127
BugcheckParameter1 0x8
BugcheckParameter2 0x80050031
BugcheckParameter3 0x406f8
BugcheckParameter4 0xfffff80003d52b28
SleepInProgress false
PowerButtonTimestamp 0
________________________
SCREEN 2:
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
[ SystemTime] 2014-01-16T13:02:18.310818900Z
EventRecordID 16320
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Utente-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 209
BugcheckParameter1 0x1
BugcheckParameter2 0x2
BugcheckParameter3 0x1
BugcheckParameter4 0xfffff88011dc312b
SCREEN 3:
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
[ SystemTime] 2014-01-12T21:11:20.510422700Z
EventRecordID 14538
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Utente-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 30
BugcheckParameter1 0xffffffffc000001d
BugcheckParameter2 0xfffff80002ee1602
BugcheckParameter3 0x0
BugcheckParameter4 0x1d500
SCREEN 4:
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
[ SystemTime] 2014-01-06T18:13:32.189215200Z
EventRecordID 10881
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Utente-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter4 0x0
No hardware was changed, some normal updates installed from win update.
Yesterday I performed a scan with advanced system care and it also updated 3-4 drivers which were obsolete (audio, realtek etc...).
I remember I got a blue screen 10 seconds after I connected a new keyboard via usb, it was installing the drivers but I remember win updates did not find them or something like that...and I got that bluscreen
Ok here's what I found.
On Janurary 16th the Event ID 41-Kernel Power coincides with the following error: "Impossible load the driver \Driver\WUDFRd for USB\VID_05AC&PID_12A8&MI_00\0."
This might actually explain everything because on January 16th I installed a new keyboard, windows was loading its drivers on win update, it didn't find it and then the computer suddendly restarted itself giving me the Event ID 41 BSOD.
Now the keyboard works, but is it installed properly? I don't think so, how can I check?
There is something I don't understand.
When I update the audio driver on windows it says updated to the last firmware, but if I check on this Advanced System Care thing it says obsolete driver and wants me to download the 80mb update... 😵
