Event viewer help??
Martin9744
136
Hey, I just randomly checked event viewer and I noticed I had one on critical
Log name: System
Source: Microsoft-Windows-Kernel-Power
Date: 21.03.2016 13:19:53
Event-ID: 41
Category: (63)
Level: Critical
Keyword: (70368744177664),(2)
Account: SYSTEM
Computer: Martin-PC
Description:
Systemet har startet på nytt uten å avslutte på riktig måte. Denne feilen kan oppstå hvis systemet uventet har sluttet å svare, krasjet eller mistet strøm. (translated: The system has restarted without shutting off in the correct way. This problem can occur if the system unexpectedly har stopped working, crashed or lost power.)
Event-XML-file:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>3</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2016-03-21T12:19:53.804125300Z" />
<EventRecordID>718</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Martin-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">6</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">3221225684</Data>
</EventData>
</Event>
this https://www.google.ca/?gws_rd=ssl#q=Microsoft-Windows-Kernel-Power%22+Guid%3D%22{331C3B3A-2005-44C2-AC5E-77220C37D6B4} also check if you have all the latest driver for your system .
