G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am having frequent crashes in Windows Explorer.
After one such crash I was invited to report the fault and then followed a
'Microsoft Online Crash Analysis - response'
In the troubleshooting section I was lead to the 'Event Viewer' with
instructions as to how to proceed.
The problem is that in the date column, no current dates exist. The last
closest one is in January 2004(for which countless entries apply) and the
next date is in 2033!
Have you any idea why current problems appear to have no entries.
Thanking you in anticipation
John King
G
Guest
Guest
With no entries in viewer,for each column go to action,clear events,after all
are cleared,click file,options,delete files,then close out.Also,go to C:
drive,open,
windows,locate mini-dump,open,delete all,then close out.Thiers also a hot-fix
for explorer crashes,#892052
> John King
