Hi all. I am hopeful someone could help me figure out what the problem could be related to. Normally I'd suspect any bad block error to be related to a failing drive, however checking SMART values it seems the drive is functioning well? The bad block errors definitely started to appear more recently. With that being said, I did experience sporadic system crashes or situations where BIOS did not detect this drive as the correct boot drive, though this would usually 'fix itself' after a restart. This is also the drive that contains the OS. I suspect I'll have to replace the drive anyway, though it's driving me a bit crazy trying to figure this out.
I have attached the error from event viewer (usually they come as a batch) and the SMART values from Crystal to compare.
Appreciate your help in advance!
EDIT: Thanks Ralston18 for the initial help and apologies for not including the full hardware details.
OS: Windows 11 pro
CPU: Intel 12600k
PSU: Corsair RM750x - bought new in 2022 for a new build.
MOBO: Asus z690p d4
Ram: G.Skill Ripjaws DDR4 32gb (2x16gb) CL18-22-22-42 @ 1.35V
Storage: ADATA SX8200PNP NVME x2 (1tb each); The affected drive has ~800gb data on it.
+ Samsung 850 EVO 500gb
GPU: EVGA 3080 12gb
OS: Windows 11 pro
CPU: Intel 12600k
MOBO: Asus z690p d4
GPU: EVGA 3080 12gb
