Every game is now lagging hard,I NEED HELP!
cezarceausescu3
This is probably something not very often seen
So recently i had some problems with my laptop,A ROG GL552V,after i hit it and probably the hard came off or something.
I took it to a service were they fixed it,then i took it to a guy who reinstalled my windows(cracked) and added a SSD.
Now almost every game i have,except PUBG and Fortnite runs at about 10 fps or less in menus and in-game i might say it`s not even 1 fps....Rust doesn`t even start it just freezes without the program to be not responding(i tried it with Skyrim,Overwatch,Rust)
I got Windows 10,looked everywhere couldn`t find the problem or answer,looking forward to receiveing a fix
Note:I am not very much into specs and pc`s so i don`t really know my specs or programs...so i might need a detailed fix on how to enter programs or settings
Also i cannot change the resolution in any game and in th pc monitor
If viveknayyar007's answer doesn't work, I would recommend getting a new computer, as the guy doing the repair may have changed out components to weaker ones, causing the machine to slow. In other words, he replaced you device with a toaster.
Do you guys install your drivers after installing w10?
https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-GL552VW/HelpDesk_Download/
Also, you dont need cracked 10. Installing the one from Microsoft woll work without the activation. It doesn't nag you like the older versions did.
MERGED QUESTION
Question from cezarceausescu3 : "A lot of problems with my pc:Lag,Resolution can`t be changed,Errors"
