[SOLVED] Everytime i turn off my PC. please help
Dadrizzle
23
everytime i turn off my pc i get this error from "null window: NVIDIA Web Helper.exe- Application error"
I have searched all over and havent found anything to fix it. i have uninstalled the driver, uninstalled Nvidia, i have upgraded to windows 11 and nothing has fixed it can anyone help me understand why and how to fix this?
AMD Ryzen 7 2700X Eight-Core Processor 4.15 GHz
RAM 32.0 GB
Gpu: strix 1080ti
this happened on Windows 10 and 11
I turn off the PC normally with windows icon shut down
Update your post to include full system hardware specs and OS information.
How do you turn off your PC: do you use the Windows power icon or do you use some switch : e.g., the case, the PSU, a power strip...?
Look in Reliability History and Event Viewer. Either one or both may provide more detail about what is happening. Right click an entry for more detail - an error code perhaps. The additional detail may or may not prove helpful.
Are you manually downloading the drivers via NVIDIA's website? No third party tools or installers.
Try running the built in Windows troubleshooters. The troubleshooters may find and fix something.
Also try "sfc /scannow" and "dism".
References...
References:
https://www.lifewire.com/how-to-use-sfc-scannow-to-repair-windows-system-files-2626161
Fix Windows Update errors via DISM or System Update Readiness tool - Windows Server | Microsoft Docs
