[SOLVED] EVGA 1080ti FTW3 heaven benchmark seems low
LudinK
81
I did a heaven test today and when comparing my scores to ones i found i was really disappointing. Trying to see if there is an issue or my score is normal.
My Specs:
Ryzen 7 1700 (stock fan)
8GB G Skill DDR4 3000
1080ti EVGA FTW3
500GB samsung 860 evo
1000w EVGA 80+ gold
I had the gpu fan at 80% and cpu fan at 100% and the temps where GPU:46 CPU:37 at the end of the test
https://imgur.com/a/diFkWOP
Unigine Heaven isn't the best for benchmarking due to being able to change settings and not always knowing what you are comparing to. Use something like Firestrike or TimeSpy instead.
*Though your minimum framerate does seem quite low. You may need to install MSI Afterburner or EVGA PrecisionXOC to monitor temps and clock speeds while running the benchmarks. Temps afterwards mean nothing.
heres the timespy benchmark
https://imgur.com/a/84ntiwp
as for the temps, ive looked all through the settings of afterburner to have on screen display however i couldnt find it however during the test, my fans were on the lowest settings and for half a second i heard them begin to go faster but instantly dropped back to lowest again so temps are running really cool. If you happen to know how to find OSD on the new afterburner settings that would help a lot.
