Evga 1300w gold psu need help I was recently playing some dying light when I heard some odd sound from my pc I investigated n
Mrludie
I figured out it was the power supply n when facing upwards it doesn't make the sound but fan downwards it does I don't understand this I've only had it for bout a month only use maybe 950wats max plz help !.
jrrdmchls
418
64
Sounds like a fan to me. Return the power supply to where you got it and get a new one OR Do an RMA to the manufacturer.
Mrludie
So should be safe to run on it till I get a new one in a few days right ? I was running it to listen playing videos games with no sound nothing was acting weird just that sound .
jrrdmchls
418
64
Probably, just make sure if you hear the noise stop to check and make sure the fan is running.
Mrludie
Okay well thank you for your help I'll probably just turn it upside so it doesn't make the sound n use it till I get a new one once again appreciate the help !.
jrrdmchls
418
64
Make sure you got airflow. Its key!
Similar threads
