Evga 280 clc with noctua fans? 140mm Fractal Venturi on 120mm slot?
thtran6
Upstanding
Oct 2, 2018
167
37
So I currently have the NZXT h500 case with a 120mm liquid cooler for i8700k chip.
I'm planning on upgrading my cooling system. Here is what I have in mind:
Evga 280mm CLC mounted on the front for intake.
140mm noctua NF A14 ippc3000 on the top for exhaust
140mm fractal design venturi fan on the rear for exhaust
Question 1: the nzxt h500 case indicates that it can only fit 120mm fan on rear but I also heard that the 140mm fractal venturi has 120mm mounting, can this work???
Question 2: As for the Evga clc, could I replace its stock fans with two nf a14 ippc3000 noctua fans? I want to know if this is physically possible and compatible. Noise isn't a problem to me.
Thank you all for your help and suggestionn.
Latest posts
