EVGA 430W + XFX RX 460 2GB possible problem?
RA_CAGoogle
9
Apparently the PSU I bought (EVGA 430W 80+) doesn't have a 6-pin connector, from what I saw on their website(I might be wrong) and I was wondering if the XFX Radeon RX 460 2GB (2-fans one) needs one of those connectors, and if I'll have to get another PSU.I can still return the EVGA 430W,
this xfx?
http://xfxforce.com/en-us/products/amd-radeon-rx-400-series/rx-460-2gb-sf-rx-460p2sfg5
or this
http://xfxforce.com/en-us/products/amd-radeon-rx-400-series/rx-460-4gb-dd-rx-460p4dfg5
i don't see any 6 pin power connector on the first, only in the second
that evga should have at least 1 6 pin power connector btw, i have a cheaper older thermaltake tr2 430 and has 1 6 pin power connector
http://www.evga.com/Products/Product.aspx?pn=100-W1-0430-KR
CONNECTOR QUANTITY
24 PIN ATX 1x
EPS (CPU) 1x 8pin (4+4)
PCIE 1x 8pin (6+2)
SATA 6x
FOUR-PIN PERIPHERAL 3x
FLOPPY 1x
see? it has 1 pci e 6 pin power connector, iti s a 6+2, just remove form the main connector body the two extra pins and that's it
the second link is for a...
this xfx?
or this
CONNECTOR QUANTITY
24 PIN ATX 1x
PCIE 1x 8pin (6+2)
SATA 6x
FLOPPY 1x
the second link is for a rx with 4 gbs of vram, that is better, most games will ask you to have at least 2 gbs of vram, you only have two with the first link, better 4 to have textures on high or ultra in games
the one is listed on the information i replied to you, the cable is called pci e
form the link i posted
the second on the left line, the yellow one that says pci-e
this psu should be enough for what you want to build, a bit small but perfectly capable
Thanks! I got it now, for some reason I thought it was just an 8-pin connector.
RA_CAGoogle: Can you confirm that you picked atljsf's answer as the Best Answer. I voted it up and I think you picked it as solution at the same time, so when I clicked I thought I had picked best solution so unselected it, then realized I probably didn't mess up, and it was coincidental, so selected best answer... I know, I'm going to have another beer
