In the EVGA GPU's graphics card manual says "Always use the cables that came with PSU" first
now all the red Vga cables from EVGA PSU's have this 6+2 pins, when you insert those I realize there is still another 6 pin on the GPU, does that mean I have to fully cancel the red VGA cables that came with EVGA PSU and open up to see EVGA GPU's cable match? or does it simply mean it is okay as long as 6+2 pin cable inserts and you dont have to use that additional 6pin on GPU itself?
I looked up installation online via youtube, but couldn't find that specific part for this model,
Attaching photo of what I mean on EVGA GPU side, as you can see the extra 6 pin still not occupied after using the cables from PSU,
QUESTION #2
After doing all the reading on the manuals and installed my ASRock Thunderbolt card, and the ASRock usb 3.1 card extension on the appropriate slots on the ASRock Extreme 4 x99 board, (Thunderbolt should go to PCI Express 2.0 (PCIE2) & USB 3.1 card goes to PCIE3 as stated on ASRock's manual)
But;
Please look at the following photo I took, this makes that area beneath the front fan of EVGA GPU quite tight, is that perfectly OK? I wanted to make sure as I am taking my time doing my first build today, and this is my most advanced PC I have ever laid my hands to
Thank you in advance for reading my posts!
QUESTION #2
But;
