EVGA FTW Hybrid in HAF 932 Advanced
malaber
49
Hello Ladies and Gents,
I am attempting to find out if I can mount the 08G-P4-6288-KR (EVGA GeForce GTX 1080 FTW HYBRID GAMING) in a Cooler Master HAF 932 Advanced case that already has a H100i taking up the top of the case. The radiator on the EVGA appears to be a 120MM, and the case only has 120mm fans in the top where I already have a radiator mounted.. I am wondering if I could somehow use an adapter like the Bgears 120-140mm adaptor to mount the radiator to the 140mm rear fan (And possibly move the EVGA stock fan to the rear of the block to increase air flow) I am not sure if this can be done, and I dont want to spend the bazillion dollars to buy the hybrid if I cant mount it in my case.
TLDR: Can I mount EVGA FTW 1080 Hybrid to a 140mm fan using a 140-120mm adaptor?
Well seems like I get to answer this myself. You can indeed mount the 120-140mm fan converter to the FTW 1080 Hybrid. You need to goto homedepot and get some #6-32 Machine screws (Item number 64237 at lowes https://www.lowes.com/pd/The-Hillman-Group-6-Count-6-32-x-3-8-in-Round-Head-Brass-Slotted-Drive-Standard-SAE-Machine-Screws/3036966) after which you can install a 120mm fan and a 140 mm fan for improved airflow.
Are they just screwed into the radiator from an angle? Do you have a picture? Or did you have to use an adapter?
