EVGA GeForce GT 730 2GB GDDR5 64bit DVI/HDMI/VGA Low Profile Graphics Card 02G-P3-3733-KR
James Dietterich
Commendable
Aug 4, 2016
7
Is the EVGA GeForce GT 730 2GB GDDR5 64bit DVI/HDMI/VGA Low Profile Graphics Card 02G-P3-3733-KR compatible with the A68hm e33 v2 motherboard?
I've actually looked up tons of benchmarks and such and found this card to be great for entry level gaming. Sure it won't play most of the newer AAA Games maxed, but it can play a majority of the games you'll find on pc, and for its price of just around $70 its great if you're on a budget, and i'm actually planning on getting this one as well.
I would go to pc parts picker, select the motherboard and then the video card, it will tell you if they are compatible!
yes it is , but dont buy anything lower than gtx 750 ti or GTX 950 mini if you want to game
loll What AAA and maxed ? even the GTX 950 cant do that ...
you can find used GTX 750 ti easily for $70 if you are on budget . and the GTX 950 used for $100
if you are on low budget , look in the used market .
here is a fast search ,
http://www.ebay.com/itm/Zotac-Gtx-750-Ti-2gbs-/331930980694?hash=item4d48a0d156:g:mF8AAOSwhOdXpn1-
offer him $60 and see lol
