EVGA GeForce GTX 750 TI FTW - Will it fit inside the CM Elite 110??
EzTec
421
Will it Blend?!?!?!?! Haha just kidding...
So before you say no because the CM 110 is compatible as it says up to a 210mm GPU, I have looked at countless videos, pages of information and I will link some for furthering your decision.
Size of the Card:
on Newegg and on Amazon the Evga FTW is calculated at 9.5inch in length which is false, According to EVGA and someone i saw on a video on youtube he put a ruler to the GPU and it comes up to only 9inches :http://www.evga.com/products/Specs/GPU.aspx?pn=6a8f5e91-8aa1-49f6-9a4a-8ae25cad9d25
Video of the Elite 110 being reviewed:
This youtube link will take you to a video where he demonstrates at 3:00 minutes a MSI R9 270 GPU which does not fit, he also mentions that if it were not for a plastic piece it would most likely fit... Now this MSI R9 is 10.08" long, and the EVGA FTW is a bit shorter. https://www.youtube.com/watch?v=X9_ouWqB5co
PartsPicker Compatibility:
This GPU that I want is not im the compatible list which upsets me however, If you look up video cards (assuming you've already selected the 110 case) and search EVGA then sort by price you will see the http://pcpartpicker.com/parts/video-card/?compatible_with=cooler-master-case-rc110kkn2#sort=d8 List, if the list is not sorted already i am referencing http://www.newegg.com/Product/Product.aspx?Item=N82E16814130768 GPU which is exactly 10" long and it shows as compatible with the Elite 110 case.
Needless to say I am being torn in a couple different directions... I really like this GPU.... I have yet to see any build have a 9inch GPU installed (if you do please just tell me lol) so I am turning to all of you in the community that i am sure know more than me on GPU's....
Thank you in advance for the help and any information you can give me.
