evga GeForce gtx 750 ti sc display issue
gabranth514
5
Installed a new gpu in a prebruilt HP envy ;
fx 8350
Psu 430w
4GB x 2
Etc.
gpu is now the gtx 750 ti sc
No extra power connector just pci express for the gpu
Previous gpu was thrown out
After installing the gpu everything was good
Updated the drivers and installed the nenecessary tools.
Now the issue are: no display which seems to work if I take the gpu out and plug it back in but that only happens 1/10 .
The other issue is that now my computer seems to freeze. It will randomly freeze at anytime though I do think it could just be the gpu that freezes. Will have to check if any functions still work by testing the sounds and disk ports.
Anywho this gpu is only one week only the the issue only started two days later. I was actually able to play star wars the old republic a few nights ago with issue. I am getting tired of this. Might have to contact Newegg for help
Are you sure you're using the proper connectors for your GPU? I've noticed that the PCI plugs coming from the power supply can be easily confused at times.
What power supply are you using?
Did you make an attempt to overclock anything?
Do you reach post (do you have a post-speaker attached to your motherboard?)
