Hello, I'm looking to upgrade my family PC as I don't have the cash to fully build my own ATM (but plan to in the next year). I think this should be fine but just want to check.
Current set up:
CPU: AMD FX-4300 Quad-Core 3.8Ghz
Motherboard: Asus M5A78L-M LX V2
PSU: Sun Pro ATX-580WA
RAM: GeIL 4GB Single DDR3 Dragon C9 1333MHz
Graphics Card: Radeon HD 5450
Not that Great 🙁
I think Ive decided to replace the Radeon HD 5450 with EVGA GeForce GTX 770 Sc w/ ACX cooler 2GB. Because of this I'll also replace the SunPro as I know its very bad with probably a Seasonic M12II-750 BRONZE ATX 750 Power Supply, as I dont want anything to damage the 770.
My main concerns are that here http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-770/specifications it says i need a PCIe 3.0 where as my Motherboard only has one PCIe 2.0 slot. The other thing I want to check is will the PSU be able to support all this + a couple of Hard Drives.
I'll also be buying these from the US as it's alot cheaper then here in Australia and relise I will need a power adaptor for the PSU, will there be any other complications with this?
I'd also love your opinions on the choices I've made, keeping in mind I will use these parts in the future when I can afford the other stuff.
Thanks for your help.
Current set up:
Not that Great 🙁
