EVGA GeForce GTX 980 Ti Hybrid - How to mount radiator?
So, you're going to swap the card? Okay that makes more sense. You can mount the radiator in place of the 120mm exhaust on your case (if it's a normal ATX case). You mount the radiator with the long screws provided, which go all the way through the radiator and into the fans.
Woody
