EVGA GTX 1070 low benchmarks?
Andre_63
Commendable
Nov 11, 2016
Hey guys first ever post. Havent had a capable rig in a while, and recently upgraded to a EVGA GTX 1070 SC. Heres my full build:
Asus H170-Pro motherboard
Intel I5-6402P (2.8Ghz)
16gb DDR4 Corsair vengeance 2133mhz ram
EVGA GTX 1070 SC GPU
120GB SSD + 1TB HDD
500w PSU
Dell 27in 1440p 144hz 1ms G-sync monitor
So Ive recently purchased an EVGA 1070 SC from best buy and ran a few benchmarks with Unigines Heaven software.
Without any overclocking, the best i could do was 92.7 FPS, 2336 score(Averages around 89 and 2210~ respectively). Ultra settings, Tesselation extreme and AAx8.
With overclocking gpu to about 2189mhz (insanely high if you ask me) the best i could achieve was FPS 97.4, Score 2453
**However this was at 1080p on a 1440p native monitor (dell s2716dg). Not sure if using 1080p on a 1440p-native monitor will have any affect. Its also 27inch if that matters.
Ive been seeing other 1070 cards on Heaven benchmark around 97-99fps stock and up to 105-107 overclocked. And these runs have a lower clock speeds than i had during my benchmarks.
I've tried DDU and reinstalling drivers. Also set up a much more aggressive fan profile, no avail.
Im new to high end graphics and have heard of the silicon lottery. I was under the impression that just applied to a cards capable max stable clock speed. It seems i can get very high clock speeds compared to other 1070 owners but am still not achieving as high of framerates. Did i just get a crappy card? Or is there a bottleneck somewhere? i can still swap it for another EVGA 1070 SC at best buy, im within the 15 day window. Sorry, im new so if i forgot to add anything let me know!
also want to mention multiple runs at 2100~mhz overclocked resulted in 90-94fps, showing no improvement and sometimes decrease over stock clock.
Ran userbenchmark. out of the box (no tweaks to core or memory speed):
http://www.userbenchmark.com/UserRun/2051136
Heres with a +125 core clock and +205 memory. Power limit 112%, didnt increase voltage.
http://www.userbenchmark.com/UserRun/2051117
from the looks of it, you've done a good job on the gpu overclock. i think its fine.
so lets just put it this way so its clear.
your gpu overclock looks fine.
but if you are comparing results of the gpu to another gpu from the benchmark. you cannot expect 1% difference even if you compare with exact parts.
so like i said before, your cpu is what slowing everything down. you can see in the quick bench that its rated 50%. i can verify that also because with my i5 6400 at stock clock with boost its around 50% also. ive also tested stock cpu+gpu and overclocked cpu+ gpu the difference is there. its not insanely substantial but its there.
before you make any other decisions, i think you should just put all that aside and just overclock the gpu and play games. if it drops below 60 or you're not satisfied with the quality then think about upgrading.
btw, if you do care for ssd speeds.. the samsung knocks everyone out. 850evo is superb
another thing u can do is clock your dram multiplier up one click. it should give you a better edge. just click the multiplier and check the xmp. it'll probably retard the cas latency +1. thats fine.
Can i clock the ram up even though my MOBO only supports up to 2133mhz?
oh sorry forgot to take that step.
emm best bet to search ur mobo model and see if anyone has done anything like that. but its not a big change either way. ur cpu is the main thing.
so have you done any gaming yet? like i said just put all this aside and just do what u wanted to do when u bought the gpu then go from there
you can use this bench and the use the advanced serch with your cpu and card and select 1 gpu used and see how you stand
http://www.3dmark.com/search#/?mode=advanced&url=/proxycon/ajax/search/cpugpu/fs/P/2151/1090/500000?minScore=0&cpuName=Intel Core i5-6402P&gpuName=NVIDIA GeForce GTX 1070
only 5 results to look at ??
your cpu is the hold back say compared to a i5 4670 or something ''stronger'' , but that's just the way it is [ physics score is all CPU processing power not any thing for GPU ]
