EVGA GTX 1080 FTW getting less FPS than normal.
apologetic_zombie
195
So recently ive been noticing that especially in BF1 I dont get as much FPS as I used to. Normally id easily be hitting 100fps ultra at 1440p@144hz. Im not sure what is going on because when I look at other people they get 100-130fps normally at these settings and resolutions. I have a slight overclock that hits around 2050-2100 @ 57-66 Celsius. Memory is around 5050-5100mhz. Cpu isnt overheating either usually running at 40-50C (fans running at 500-900rpm)
Specs for system:
Cpu: i7 6700k@ 4.6ghz
RAM: 32gb (4x8gb) Corsair LPX @3000mhz
Mobo: Gigabyte Z170X UD5
PSU: Corsair RM850
Cooling for CPU: H100i
Hi did you find a solution to this? I am having a similar problem. EVGA GTX1080 FTW Im playing at 1080p until i upgrade my monitor and i have fps from as low as 60 to around 130ish!! Whereas a few days ago i was getting 130-150 easily. All benchmarks run fine, Unigine Heaven Score was 2870, 67c temp and no throttling.
i7 4790k
gtx 1080 FTW
Corsair Rm650x PSU
I ended up just formatting windows with a clean install which basically fixed my issue.
