So I am going to buy the 780t case and
• add a hydro series corsair h115i 280mm radiator to cool the CPU (which will exhaust at the top)
• a 140mm fan exhaust at the back
• 2 140mm fan intakes at the front
But then there is no space for the hybrid gpu radiator except for the bottom of the case.
I would prefer to mount the radiator to exhaust at the bottom of the case however, I have heard this is not very good since hot air rises and air pockets in the AIO tube would cause splashes of water down the tube.
Do you think this would be a problem or would you suggest:
• going for an air cooled GPU
• replace the front 2 fans with 120mm fans and mount the radiator at the front [I do not prefer this option since it would mean less airflow inside case and the tube going across case may obstruct airflow to motherboard]
I am looking for a solution to offer the most effective cooling for an overclocked gtx 1080
