EVGA GTX 1080, same price but what is difference?
Masoner
270
29
I'm looking to buy a GTX 1080, these two are on sale but a bit confused on the difference.
EVGA GeForce GTX 1080 GAMING ACX 3.0, 08G-P4-6181-KR, 8GB GDDR5X, LED, DX12 OSD Support
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487246&cm_re=GTX_1080-_-14-487-246-_-Product
EVGA GeForce GTX 1080 FTW DT GAMING ACX 3.0, 8GB GDDR5X, RGB LED, 10CM FAN, 10 Power Phases
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487252&cm_re=GTX_1080-_-14-487-252-_-Product
Both are 449 or 429 (after rebate) but... they are the same no? is there one more powerful than the other and if so what am I missing or not seeing to tell me.
Thanks for the help !
Masoner
270
29
well from reading the descriptions they are exactly the same but .... I just dont' know.
I just kept looking it up and it seems the DT = Detuned
The FTW are normally higher binned chips than the standard vers, and they have better cooling, more power phases, more OC headroom.
But that FTW is the DT vers so you would be down to better cooling.
