EVGA GTX 570 HD DS Strange DVI port issue... (SOLVED!!!)
doom2pro
Commendable
May 3, 2016
Hello, I have a strange issue I cannot resolve... My EVGA GTX 570 HD DS card thinks there are two analogue displays connected to the two DVI ports, and when booting the main DVI port gets a blank signal (signal is detected by monitor but it's a black screen).
The machine boots fine, I can VNC it or use HDMI port to control it, and I ran artifact tests and benchmarks and it runs perfectly fine, it's idling at 30's C and load 58C.
When I boot the machine with ONLY HDMI connected I get a no signal all the way until the login screen where windows is set to use HDMI port. However nVidia Control Panel -> Display Manager seems to think there is two analogue displays connected (I guess to the two DVI ports) even if nothing is connected to them, and the EXACT same card I have in another machine when it's connected to HDMI will only show HDMI in display manager...
So I am inclined to think *something* is tricking the card into thinking the DVI ports are in use, and on boot it tries to output a signal to the main DVI port but it's blank and only when windows loads (and has been specifically specified to use HDMI) does the HDMI port work.
I replaced the 14pin 74AHCT08D IC (which I think multiplexes the signal to the four outputs) on the board just in case it was that, but no dice, same issue.
I'm perplexed, any suggestions?
Problem Fixed! Thankfully it wasn't an internal GPU Fault, but a board fault! I noticed some SMD components were missing a few days ago, and I replaced them but it didn't have any effect...
Well upon further inspection of images of this same board I found on Google Image Search I noticed one of the "Capacitors" that was missing and that I had replaced (labeled C824) didn't look like a capacitor, the component was too dark, it looked like a ferrite inductor (Choke), so I took a working card (same exact model) and tested the component in question with a multimeter and sure enough it was a dead short (meaning an inductor NOT a capacitor which would be open circuit).
See Image (Blue Arrow points to Inductor)...
See Image (Blue Arrow points to Inductor):
So I took a similar sized component from another dead Graphics Card (GeForce FX 5700LE) I have lying around just for this purpose, I desoldered the SMD Capacitor I had put in before, and soldered in the inductor.
I put the card back in test machine, put DVI cable onto main DVI port, turn monitor on, power up and... BIOS SCREEN! SUCCESS!
Anyway, hope this helps someone 😛
