EVGA Gtx 750 ti FTW ACX fan noise
ironmaster
112
I am planning on getting this graphics card and I heard that the fan noise on it is really loud, even when it is in desktop mode. That is a deal breaker for me because I don't want to have to hear the fan when I'm on desktop, it doesn't matter as much when I'm gaming though.
Update:
I would RETURN the card if unopened since it appears there is no fix that will work.
I'd go with a Gigabyte model instead.
If you ALREADY OWN the card the best advice I can give is to MOD the card with a Noctua fan (I think the one used is 92mm?).
http://linustechtips.com/main/topic/185325-a-simple-mod-silencing-the-evga-750ti-ftw-w-acx/
EVGA has a BIOS update to fix the the too-aggressive fan profile and reduce noise.
This fix is already applied to recent cards.
*However people claim the fan goes back to the noisier profile after installing the NVidia drivers. Not sure what is going on since I thought fan control was done entirely by the card itself.
So you may want to investigate further.
Update:
