EVGA GTX 760 issue
Jamburger
Commendable
Dec 25, 2016
34
SO I was having an issue with World of Tanks crashing. So I decided to check my video drivers, which I was behind on last update. So I updated it, then tried World of Tanks, still didn't fix that problem. So I rolled back that update. Trying one thing at a time, to see if it fixes WOT. I decided to take side off computer and blow it out. Thought maybe overheating could be a problem. Coretemp didn't show anything extreme, but thought why not to rule heating out. I cleaned up everything blow out, cleaned fan blades, etc. After I turn computer back on monitor didn't come up using HDMI. So I hooked up DVI cable, monitor started working. Now I have yellow triangle on video card?
Windows has stopped this device because it has reported problems. (Code 43)
According the forums I read, I can uninstall drivers and scan for hardware changes and it will find drivers and update. I tried that and it is still giving same error message.
I have reconnected cables and reseated video card, but still have error. Not sure if this is part of the problem I was having with WOT either?
Any help would be greatly appreciated
Ok Greg interesting!!! I uninstalled the display adapter, which took away the EVGA GTX 760 and the onboard graphics (Intel HD graphics 4600). I restarted computer. It loaded the onboard graphics but no video card at all?
Also I don't understand the DVI cable is connected to the video card but I still have display?
So I tried to update drivers for video controller with the white question mark? I got an error message. Windows found drivers for your device but encountered an error while attempting to install them. NVIDIA Geforce GTX 760. This operation requires an interactive window station.
