I built a PC back in the summer, but didn't need a graphics card at the time. I have recently purchased an EVGA GTX 770 2GB Version and a new Corsair CX600 PSU to go with it (I had an old crappy Raidmax one which I don't trust). However, when I put the card in ANY of the PCI-E slots on my motherboard the PC boots, the fans on the cards start spinning, but it says there is no signal to the monitor. At first I just had VGA plugged into the monitor with a VGA to DVI-I adapter plugged into the DVI port on the card. That didn't work so I bought a DVI-D to DVI-D cable, and that doesn't work when plugged into the DVI-I or DVI-D ports on my graphics card, put it does work when I plug it into the DVI-D port on my motherboard.
I don't know what to do at this point. I don't think my monitor is the problem because it works with VGA and DVI-D when plugged into my motherboard. I don't think the power supply is the problem because the fans spin up when I turn it on, but it might be (I could try with the Raidmax but I'm scared of it not being able to handle the GPU). It might be the graphics card, or it might be that none of the PCI-E slots on my motherboard don't work. Either this or I'm just doing something wrong. This is my first time building a PC and installing a graphics card, I think I know what I'm doing but I might be making some rookie mistake. Any help will be appreciated!
PC Specs:
CPU: Intel Core i7 3770k - http://www.amazon.ca/dp/B007SZ0EOW/?tag=pcp0f-20
RAM: G.SKILL Ripjaws X Series 8GB(2x4) 2133MHz - http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231468&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
Motherboard: ASRock Z77 Extreme3 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157330&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
GPU: GeForce GTX 770 2GB w/ACX Cooling - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130919&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
Case: NZXT Source 220 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16811146083&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
New PSU: Corsair CX600 - http://www.amazon.ca/dp/B0092ML0OC/?tag=pcp0f-20
Old PSU: RAIDMAX HYBRID 2 RX-530SS - http://www.newegg.ca/Product/Product.aspx?Item=N82E16817152028&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
OS: Windows 7 Home Premium 64-bit - http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116986&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
Monitor: Viewsonic VA2248M-LED 22-Inch - http://www.amazon.ca/dp/B004KCI7Y0/?tag=pcp0f-20
EDIT: I think I still have my HD4000 Drivers still installed. Could this be the problem? What do I have to do?
PC Specs:
