(EVGA) Gtx 770 on 550w Power supply?
BattleX100
Commendable
Apr 4, 2016
31
I currently have a 550w power supply on my rig and buying a new graphic card since I don't have one yet.
The calculator I found on Linustechtips power supply video seems to say that it should be okay.
http://outervision.com/b/5lT4yL
However, officially the Gtx 770 is listed as requiring a minimum of 600w power supply. So confused here. Please help me out whether I should get the Gtx 770 or not?
The official power supply requirements are inflated to provide a little more safety margin with low-quality power supplies that struggle to safely deliver the wattage they promise.
A good 550W power supply is plenty with a GTX 770. The question is whether the model you have is good quality.
Only the best 550W PSUs can reliably handle the GTX770 on long term. <-- note the "long term". The card will most likely work if your other components are relatively modest in terms of power requirements and no overclocking is involved. But longevity of your PSU will certainly be lowered.
For starters, the 770 requirements call for 42A on +12V rail (for the whole system, not just the card), and not many 550W PSUs can provide this. XFX/Seasonic and a few others do, but they are all best in class - anything less or more budget and you are out of luck.
The alternative is to purchase GTX970 instead of 770 - not only you gain more performance, but it also uses 50% LESS power. GTX970 usually needs only 28A on +12V rail. So most 550W would be more than fine with 970, even on long term. Not so with 770, however.
It doesn't take that much. The GTX 770 itself draws just under 200W at full load, and the FX-6300 under 100W when it's at full load. So even in the rare instance of full load simultaneously on GPU, CPU, and the rest of the system, the PSU would be delivering less than 350W.
Ohh okay thank you very much guys I will steer clear from that GPU. Thanks for sharing the link Alan that is very informative.
Is it okay to use a R9 270x, R9 280 or a GTX 970 with this PSU? I think those cards require not more than a 550w.
GTX970 should work fine, provided you don't overclock anything. It is also the best in terms of pure performance and has the lowest power requirements of all 3 cards you mentioned.
Regardless, consider replacing the PSU in near future - it is far from being a quality model.
Oh okay thank you very much! I was considering getting the Gigabyte R9 270x instead and overclock the crap out of it lol. But I'd wait until either for a Gtx 970 or till I can replace my PSU.
The R9 270X uses about 125W in games, the GTX 970 around 170W depending on model.
