EVGA GTX 960 4GB FTW vs EVGA GTX 960 4GB SSC Need Help
deahtcythe
6
Hi everyone, I'm just new here.
I'm planning to get one of this cards (EVGA GTX 960 4GB FTW vs EVGA GTX 960 4GB SSC) the models are these (04G-P4-3969-KR vs 04G-P4-3967-KR) but i want to know if the ftw works the 20$ i can avoid if i buy the SSC , Do it really works 20$ more or should i save money for other stuff.
Im actually in build of my new pc and if i can save 20$ for other stuff it will help me hope you guys can help me im not english speaker so dont destroy me because any words i had write wrong thanks for your help ..
you can check the prices here 😀
FTW $229.99 vs SSC $209.99
http://www.amazon.com/dp/B00SC6HAS4/ref=twister_B00UTH4YPG?_encoding=UTF8&psc=1
I guess it all depends on how much $20 is actually worth to you. If you are on a tight budget and still need more stuff, dropping back to the 3967 won't...
i will buy it from amazon what about the drivers and other things i will use this card for atleast 3 years
do the ftw worth the 20$ more i will spend or should i go for the SSC i ask because i need to buy other things like the power supply the mother board and other stuff, If the ftw really worth it i will pay for it then..
I guess it all depends on how much $20 is actually worth to you. If you are on a tight budget and still need more stuff, dropping back to the 3967 won't make that much difference in real life. It's more important that you put the extra money into the PSU than the card.
at last i just bought the SSC with the tax i only save $5 from the $230 i was thinking to spend on it thanks for your help
