Evga Gtx 960 SSC Acx 2.0 fans not spinning
Clint_4
Commendable
Mar 31, 2016
On initial start 1 fan start spinning while the other fan spins a little then stops again the spins a little then stops.? then they both stop spinning is something wrong or is this normal
I believe this is normal with EVGA ACX coolers. They are designed to turn off when your GPU isn't in heavy use and turn on when it reaches above a certain temperature. Your GPU is probably idling near that temperature so that's why your fans are acting odd. Unless they aren't spinning while gaming, I wouldn't be worried.
