Good afternoon, community. I am planning to purchase 3rd party cooling solution to enhance my gaming experience and I need some advice from you since this is my first time customizing my GPU.
First, here are my desktop system
CPU : Intel Core i5-4690K Processor 4.5 GHz(Overclocked)
SYSTEM : Windows 10 Pro 64-bit
CPU FAN : Cooler Master Hyper 212 EVO
MB : ASUS Z97-A ATX DDR3 2600 LGA 1150 Motherboards
RAM : Corsair Vengeance Pro 16GB (2x8GB) DDR3 2400MHz PC3 19200 Desktop RAM
GPU : EVGA GeForce GTX 970 4GB SSC Gaming ACX 2.0+ Cooling Graphics Card(Overclocked)
PSU : Corsair CX Series, CX600M, 600 Watt (600W)
SSD : SanDisk Ultra II 240GB SATA III
HDD : WD Green 1 TB Desktop Hard Drive: 3.5 Inch, SATA III, 64 MB Cache
CASE : Corsair Carbide Series SPEC-01 with 2 * 160mm fans in the front panel, 2 * 120mm on the top of the case, and 1 * 120mm fan on the back of the case.
Now,
This might sounds stupid but I overclocked both my CPU and GPU to get most performance of out them. After I overclocked my GPU(It runs at 1450Mhz right now), I've noticed that graphic driver crashes sometimes after overclocked so I turned my GPU fan speed to 100% then my overall ambient temperature inside the desktop is really hot and I was worried about high temperature might affect other component's performance, especially CPU.
So I searched for quite amount of time and come down to purchase
1) NZXT Technologies Kraken G10 Liquid Cooled GPU Mounting Kit &
2) Corsair Hydro Series H55 Quiet Edition Liquid CPU Cooler
to liquid-cool my GPU. But after more searching, I also found out that VRM on GPU can affect my overclock performance and (this one is not sure but...) VRAM might also affect the performance as well.
So along with those two(1,2) main cooling parts, I am also planning to purchase heatsinks for both VRM and VRAM with
3) Enzotech MOS-C1 MOSFET Heatsinks (for VRM)
4) Enzotech MOS-C10 Forged Copper MOSFET Heatsinks (for VRAM).
This setup costs almost $120 dollar.
but then I thought what if I sell my GTX 970 SSC and with that money plus $120 that I was planning to purchase cooling soulton, just buy used GTX 980 Ti? but then I also thought 980 Ti might be overkill for my monitor(FHD, 60Hz)
So, what do you guys think?
Do you think
1) purchasing 3rd party solution to improve my GPU performance is better or
2) sell GTX 970 and buy used GTX 980 Ti ?
Now,
Do you think
