Evga gtx570HD problem
Petar Raickovic
427
Ok i have evga 570 gtx HD and when i play, diablo skyrim Cs go my screen goes black and it says driver stop working but when i alt tab in game pc blocks and needs to be restarted? how to fix that.. i have reinstall drivers ( windows ) everything and the problem is still there
toddybody
Hey Friend, sorry about your troubles...
Since you've re-installed drivers...it may be an issue with either your GPU or the motherboard. I found these instructions on another Tom's forum...hope they help:
"1. Turn off the computer and unplug
2. Remove Graphic card
3. Plug the monitor to your video output
4. Turn on the computer
5. Click on start and type msconfig
6. Select the Boot tab and click on the box that says Safe boot with minimal selected.
7. Apply then click ok.
8. DO NOT RESTART.
9. Shut Down computer and unplug
10. Install Graphic card
11. Turn on the computer (should boot into safe mode)
12. Go into Device Manager
13. Expand Display Adapter
14. Disable the Intel(R) HD Graphics 4000 driver. [or other integrated graphics] (DO NOT UNINSTALL)
15. Click the start button and type msconfig
16. Unclick Safe boot
17. Restart"
