EVGA Liquid/Water Cooler For Titan XP/Pascal
DrGreer
136
I have a Titan X Pascal and I want to water cool it with a closed loop. I've found a few solutions for this but the best GPU coolers for GTX seems to be the EVGA hybrid kits: https://www.evga.com/products/productlist.aspx?type=18&family=Accessories+-+Hardware&chipset=GPU+HYBRID+Cooler .
At one point, EVGA was selling a Titan X kit but it's out of stock everywhere and not even listed on the EVGA site anymore. Here's what that looks like (Their China site still shows it): https://cn.evga.com/Products/Product.aspx?pn=400-HY-0990-B1
So that seems to be gone but I think they were selling that before they came out with their 1070/1080ti cooler: https://www.evga.com/products/product.aspx?pn=400-HY-5598-B1
The problem is, if you want to use their standard 1080 liquid cooler (https://www.evga.com/products/productlist.aspx?type=18&family=Accessories+-+Hardware&chipset=GPU+HYBRID+Cooler) with a Titan X, you have to modify the cooler with a grinder/dremel. I don't want to do that.
Question: Will the 1080ti cooler fit my Titan X Pascal without any modification? I see it's more expensive so I'm guessing there must be some physical difference.
those "hybrid" coolers are kinda loud.
the best closed loop solution is NZXT G12 + whatever compatible AiO (most asetek maid will work).
